Hi, My '86 turbo was still running on its original head gasket and all but a few of the cooling system hoses. Although it was running fine I asked Redline Racing (my Indy) what they thought the condition of these components would be like. A few weeks earlier they'd changed the CHG of another '86 turbo which also had its original gasket fitted. This one had large sections of gasket missing between the coolant passages and was in a mushy condition.
So I decided to have my cars CHG replaced as a precaution. I also asked RLR to check some other components whilst they had the head off and access was afforded into usually hard to reach areas. Here's a summary:
Head gasket was worse than the other '86 turbo's. They showed me a photo and it looked the sail of a battleship that had not fared well in the battle of Trafalgar. It too was mush and could be scraped off without the use of tools.
Cylinder bores, very good. I've run it on Mobil 1 Motorsport 15W50 since 45k and it's now done 70k miles. The valves were also fine.
Valve seats were worn slightly. These were re-cut and hand lapped, plus new guides were fitted.
The original radiator was weeping slightly at the core to side tank flange. So it was replaced too.
Nearly all coolant hoses were found to be very hard, hardly gripping the tubes they were clamped to. So all hoses made accessible by head removal were changed. Some vacuum hoses were also changed whilst access was good. A leaking heater control valve was changed. RLR reckon 95% of all hoses are now new. I'm impressed with a coolant hose that does not give up after 26years, but not changing them was I feel tempting providence.
Porsche were able to supply every hose, only one being on back order. Excellent service for a car of this age.
The starter motor was found to be full of dirt and rust. It was stripped overhauled and refitted.
Thought you'd be interested and that these findings might help in planning your own cars future maintenance works.
Regards Paul
Regards Paul
