tom_babbs
hello all,
As the title says i am going to take the engine out of my 1983 944 shortly as a result of me chasing an unconfirmed oil problem to the point of having the engine in bits in the engine bay.
I think the problem is that the oilways are just gunked up so i am going to take the engine out and then strip the bottom end and give it a right good cleaning! I have already stripped the head off and it will get a bit of a spruce up and then re-fitted once the engine is out.
The first question is engine out the top or the bottom, i understand that i will have to drop the front crossmember either way but i think i will be able to lift the engine easier than lifting the car. (i have borrowed an engine hoist)
Next i plan on replacing all gaskets etc whilst i've got the engine out, is there a list anywhere of all of the seals and gaskets i need to replace?
Cant decide if i should replace all the belts and pumps whilst it is out any advice?
In the search for a bit more power whilst it is out should i; skim head to raise compression, polish inlets and outlets, lighten fly wheel (buy alloy one or get the existing one skimmed?) is there anything i can do to the fuel system, any other easy power gains to be had?
All ideas /advice greatly appreciated thanks Tom
