Oli,
You make is sound as if I'm racing a car that isn't well prepared and has faults.
This is simply not the case.
I have a lightweight race battery, yes it's rated at 700 CCA but its got 10mm connectors, so it's severely compromised in terms of current capability, the starter cable then passes to a FIA approved cut-out switch.
The battery is capable of a few starts maybe 30 seconds of cranking before it gives up, but it's not turning the engine over or providing the voltage that the "Bosch Standard" battery would.
It's the price you pay for meeting the regulations, a lead acid battery is not permitted in the same area as the cockpit, without being fully encased, the red-top gel battery is the only FIA approved battery exception.
That would apply even if it were in the standard location.Mine is on the passenger-side floor, reducing weight and putting lower and between the wheels.
The car starts reliably at all times, it's a Porsche
Even when V. hot, if the engine is switched off for 2 minutes it starts on the button.
It is less energetic if it's only off for 20-40 seconds, just time enough to jump out and belt the next driver in.
It still starts but it takes 5-10 seconds of cranking, and in a race 5 seconds can be the difference between 1st and 10th.
I'm just trying to optimise that process.
If I was prepared to carry the extra 20Kg around I'd put the standard battery in, but it makes a mockery of having taken all the glass out and putting plastic windows in.
