Engine bay jetwash?
- Thread starter AntB
marcoturbo
alwigley
Copperman05
Disconnect battery
Using tin foil cover and wrap it around any electrical items you see that need to be protected from water (HT leans, dizzy, etc), , the foil will nicely encapsulate things and keep water off.
Use a good (environmentally friendy) engine degreaser, the citrus ones are good as is Bilt Hambers Surfex HD, dilute or use neat and work into nooks and cranies using varius brushes. You may want to wear gloves too.
Once cleaned rince off with hose and slow running water.
Reapply grease to headlight mechanism and bonnet release. Reconnect battery.
Finish with airospace 303 protectant and your done.
Edd
However the best method is, as a few on here have said, to use a cleaner and some brushes to scrub the junk out. (Jetwashers actually aren't that effective at removing well-caked-on dirt.) Then wash it all off with a jetwasher on a 'fan' setting.
will lyons
now all I do is a quick spray with the cleaner followed by a rinse with the plant sprayer and final spray over with a rubber protector leave to dry then rub over the polished cambox and air intake takes a while but worth the effort
