James Shunt
All
Firstly congratulations on the forum - it's run well and the contributions are more worthwhile than on most forums I've seen.
I'm very close to starting an emergency at my bank by joining you - I'm planning spending more money than I can really afford on an early 993, probably LHD, after many years of dreaming about getting a 911. (I just wish there was a Porsche team in F1 and my boyhood hero - there's a clue in the name I've used - drove it!)
I've been put off the 3.2 as it's a bit raw and the 964 because I'm not confident enough that I'll find a "right" one. I did a lot of research on 964s but worried about oil leaks, clutch problems and expensive servicing, and that reports of high running costs that would probably cover the price difference vs a 993 within 5 years. Besides, the 993 is the prettiest and I quite fancy a car that will become a classic rather than one that is a classic now.
The common theme among you all seems to be that it is worth getting an independent expert to check out your potential purchase, then use the report to negotiate to get the asking price cut to get the relevant work done. I've only ever seen one mention of such an expert (and I haven't got his name to hand). Have any of you used one before and did you think they represented good value? Is it true that 75% of what they do would come up at an MOT test?
Thanks in advance for any answers you may have.
James
James
