ORIGINAL: DavidL
Do these EBCs operate as a boost and afr guage too?
If so great, if not no I'm not going to be playing with it too much either.
Hi Dave
They do give boost readings but not afr I'm afraid, you need the innovate or similar for that. A top EBC does far more than just control boost though, I can't comment on the GReedy as I've not used one but know that those who have swear by them and for something that's quick and easy to set up they are great. However if you want the best then imho there is only one EBC and that's the APEXi-AVCR.
It's not possible to list all of it's functions here and to be honest you need an expert to give it the justice that it deserves but here's some of the functions. You can monitor in either digital or analogue display, Boost,RPM,Vehicle speed( the unit will not read the 944 ouput for speed),throttle position,solenoid duty cycle and injector cycle( can't remember but may need ertra's for this last item).
With the avcr you can set boost for all gears, you can set boost according to engine rpm, like most EBC's you can preset two maps for boost control but with the avcr you can also add a scramble switch ( bit like Palmer racing cars) to increase boost further at a predetermined level and for a predetermined amount of time.
The unit can also be switched to learning mode where it learns how much boost to use according to the rpm and the gear that is being used. Duty cycle can be adjusted to help reduce turbo lag. The unit also records and displays in graph form what's been going on during that spirited drive up the motorway.
This has only just touched what this unit can do but if you search on Google you'll find everything that you need to know, including installation and user manual's.
regards
Pete
