GoggoTS300
good day to all
After getting rid of the vibration I now have another problem that has appeared the build up to it is as follows
drove car to work approx 20 miles no problem after about 2 hours drove car a further 6 miles and the generator/ battery light came on car was parked in carpark for about 5 hours then started no problem with no warning lights, after approx 4 miles the LED dash instrument (where warning signs show) started to blink this got worse and I noticed that the volt meter was pulsating at the same time between 12v and 14v
gen/battery light came on approx 3 miles later.
after doing approve 5 miles the psm inactive light came on then lcd panel when off and the dash lit up like a christmas tree and the engine stopped and I coasted to a stop.
AA came out and tried to jump start result nothing not even the starter motor clicking
removed battery (no mean feat by the side of a busy road!) put on new battery result as above
car recovered home Only 3 miles away
if the battery Which shows 12v is left connected the following is happening the engine cooling fans are running wipers will jolt turn the key nothing not even a click
only other thing to add on one occasion the press brake pedal light came on.
I suspect the alternator is duff but cannot understand why the car will not jump start any ideas please
Best regards and thanks for any suggestion
Nicholas
PS it is 05 3.2 Cayenne s
Nicholas
