pauljmcnulty
Received tonight, any ideas?
[FONT=arial"]Hi. A few months ago i purchased a 944S2 for my son to use. I am a club member but not on the 944 register and as I feel at the moment will not become one preferring to get shot of the car. At my age I am an die hard air cooled man and have 2 x 356, 1 x 2.2 litre 911 and a 912 to play with which give no problems but the 944 has been a bit of bad luck. I would like some help with a technical problem and prefer not to ring Bert Gear at work as it is not a simple problem to explain. I assume you have his e mail number so can pass my request on.![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
[FONT=arial"]The 944 is in super condition, has done about 144k and has full porsche or specialist service history and extensive work is documented. It is mechanically sound with perfect oil pressure and shiny black bodywork. It has obviously been well cared for. When it runs it is ( I must admit) an absolute dream to drive. Some weeks ago it developed an electrical problem which resulted in a misfire, persitent cutting out, a flat spot and engine surging from 0- 3000rpm when you tried to keep it running. I put it into a Porsche "specialist" who changed just about everything except the ecu as no one thing seemed to solve the problem. This included all knock sensors, air meter, TDC sensor, fuel regs, lamda probe, temp senders, relays and even the alternator. Having got it back and only a few days later it was as bad as ever so he agreed to lend me an ecu. On plugging in it ran like a watch. On opening up the old ecu it had signs of a blown component so I put it down to bad luck to have spent the money on all the pther bits. It has been great for a five weeks but the symtoms have returned. This has obviously cost me mega bucks already and I do not feel like taking it back to the dealer . If I do he will claim to have spent the time and the parts diagnosing it so it must be something else. I am not knocking him as he obviously tried everything to cure it![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
[FONT=arial"]Current symptoms are when cold it will start and run perfectly, warm it up and the problem comes back it will flat spot, surge in revs and die and then it will not start. Leave for a while and it will start again and run Ok maybe for 10 miles or so and then play up again.![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
[FONT=arial"]Any idea what it might be? It is causing me to dislike the damn thing so much I am vowing not to buy another water cooled Porsche ever again.![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
