EBC Yellowstuff brake pads
Laurence Gibbs
Thought i'd update on how i got on with these. Well i have now done Spa 3 days and a brands indy and a brief session at lyden with the yellowstuff's installed. My first few laps at Spa scared the life out of me with virtually no pedal and no brakes ! after coming in and checking for leaks etc i came to the conclusion that i had not bedded them in correctly and the "brake in " material had'nt . A few more laps back out and the pads bedded in and low and behold decent brakes ! It took virtually the next three days to become used to the feel of the harder compound and the consiquent later braking that they can produce. In fact you have to be fairly brutal with them to get heat into them before they are at there best. They are to me at least an improvement on the o.e. pads with increased stopping power but they do lack a degree of initial bite and feel (which i guess is down to the harder compound) They still have plenty of meat left on them after all of the above so seem to be reasonble in the wear department.
To sum up bed them in carefully. Better stopping power, allows later braking . Less bite and feel(bit wooden)compared to standard pad but to be expected i think. So far wearing well . Overall positive i think.
Can't easily comment on the discs as they are getting on a bit anyway. Just checked back through my history file and found i changed the fronts in late september 03 ! rears not changed as far as i can remember ! so me thinks disc change might be good idea.
ORIGINAL: Laurence Gibbs so me thinks disc change might be good idea.
Almost certainly don't need to say this to you Laurence, so for the possible benefit of the less mechanically minded. The pads will have taken on the shape of the existing discs, so if at all grooved (and they probably are) just be carefull initially after the change as the pads will only be touching the discs on their high points.
Not sure with harder pads how quickly they square back up, there may be some mileage in your belief Melv. Have to admit it was abit of a shock when i saw the date on the reciept they really don't look that bad considering and of course the rears don't have as much to do. I am going to have a better, more technical look at them (check actual thickness etc) and will probably run the pads out before i change but it will depend on what i find. Last four years for me probably equates to about 10k road miles at a guess and about 12 to fifteen track days again at a guess.
ORIGINAL: Melv Change discs? =change pads.....[8|]
Would tend to agree as a general rule, but I'm braking that at the moment. Had to change pads at Spa & did not have discs with me. Had to change discs after the 2nd day at Spa & the run home. Being a QS, there is no way I am chucking an almost brand new set of pads away[;)] I've now done about 700 miles of fairly gentle road use (the trip to Le Mans) & the (very hard PF97) pads are almost gripping the discs accross their entire width now.
How do these compare to Pagid Yellow RS29s? Are they different manufacturers attempts to make an identically performing product?
Can't comment as have never tried the Pagid Yellows. There are a few websites that quote the tech spec's of the different pads that may help give you some feel for the differences. They are imho an improvement on the standard pad for ultimate stopping ability but have less feel. That's about the sum of my findings. Sorry can't be of further assistance.
