Dyno Run/AFR/Fuel Pump
- Thread starter scam75
robwright
ORIGINAL: robwright
I suppose I could give it a go and see wat response I get from the AFR. Just try 1 PSI increments.
The wideband is a worthwhile addition but when you start running the injectors near their limit it wont tell you if one is under fueling a little, are you using a 3 bar FPR ?.
ORIGINAL: robwright
I can't say how old the HG and injectors are. If I were to have a guess I would say the injectors at least were probably original. Can't think of a reason why they would have been changed. The car was stock until I got hold of it. I suppose I could give it a go and see wat response I get from the AFR.
The wideband is a worthwhile addition but when you are running the injectors near their limit it wont tell you if one injector is under fueling slightly,that's the benefit of flow matched sets, are you using a 3 bar FPR ?.
ORIGINAL: robwright
Just out of curiosity where does on getb55lb injectors from??
Promax, JMG, the low impedance Siemens seem to be the plug and play option but your chips need to have a suitable map.
Diver944
ORIGINAL: robwright
I don't think the K26/6 could produce more than 18 PSI anyway.
My car couldn't hold 18 psi with the K26/6 turbocharger and that was even with a DPW hooked up to an electronic boost control. On the road it would hit 18psi by 3500rpm but almost immediately start dipping down to an eventual 12 psi by the red line. It had standard injectors with a 3 bar FPR and Guru chips and ran slightly richer than optimium as this Dyno shows
ORIGINAL: robwright
Pauly yes running 3 bar FPR. A must for Tial DPW. LT are you using the Lynsey reworked wastegate then?? Just out of curiosity where does on getb55lb injectors from??
Mine came from Promax when Andy did my Level 2 conversion. I didn't strictly need them at the level of power I am running at present but you never know, I might want to turn it up a bit some time in the future.
This is the wastegate I am using:
http://www.promaxmotorsport.co.uk/products/35-dual-port-wastegate-manual-boost-controller.aspx
