Drivers side wing mirror not adjusting.
Sylvian
The car went into the bodyshop for some paint and to have a new check strap fitted, on the cars return the drivers side mirror wont adjust, but the passengers is fine. I have tried unplugging and re plugging the switch, checking that the switch is the correct way round (which it wasnt at first), I even replaced the switch and fuse which made no difference. Is there anything else I could try which would be easy enough to do myself?
There is a round multi-pin connector where the mirror motor plugs in, which would be worth checking. IIRC you can get to it by removing the triangular plastic panel that the switch clips in to. The panel unclips from the bottom, and slides upwards.
