Drivers door (RHD) electric cable routing
Trikster65
Hi all
I have an issue with broken electric cables to the drivers door. The electrics work with the door closed (most of the time) but short when fully open.
I can't seem to find the routing of the cables into the car from the middle grommet.
How do I get to that cable from within the car?
Trying to avoid removing the door, which seems a bit extreme.
Any photos you can share would be great.
Had similar with a VW and removed door card, disconnected wiring inside door to give slack and then pulled away conduit / tube between door and body to repair damaged cables and reassembled.
The damage to my cables was at the door end junction of the conduit and visible on pulling away the conduit.
Hope this helps
Great! Thank you for sharing!
Hi all
https://wincraftcasinohu.com/ka/
This is a pretty common issue and you’re on the right track suspecting the loom at the door hinge. You don’t need to remove the door. The wiring runs from the door through the rubber grommet into the A-pillar and behind the kick panel. If you remove the lower trim/kick panel and gently pull back the carpet, you should be able to access the loom from inside the car. Often the insulation breaks right where the wires flex as the door opens fully. Carefully pulling a bit more slack through the grommet usually makes the damage visible. Photos would definitely help once you get access.
This is a pretty common issue and you’re on the right track suspecting the loom at the door hinge. You don’t need to remove the door. The wiring runs from the door through the rubber grommet into the A-pillar and behind the kick panel. If you remove the lower trim/kick panel and gently pull back the carpet, you should be able to access the loom from inside the car. Often the insulation breaks right where the wires flex as the door opens fully. Carefully pulling a bit more slack through msn games the grommet usually makes the damage visible. Photos would definitely help once you get access.
When you inspect and identify a problem, having photos will help in determining the extent of the damage and deciding how to repair it. If there is a problem, you should carefully check whether the wires are completely broken or just temporarily disconnected, as pulling on the wires can reveal the problem more easily.
