944 man
Has anyone used a Dremel with a cutting bit #561 or similar? It looks a little like a drill bit, but its actually a cutting tool with a helter skelter shaped cutting edge, instead of a drills usual helical groove.
Im trying to cut out a shape in polycarbonate (and aluminium sheet after that) using this, instead of a jigsaw, but Im struggling - principally because the tool isnt held firmly enough, so it isnt cutting properly.
At the moment Im trying to do it freehand, but I wonder whether a funnel shaped guide (Dremel #565) that I can use to bear against the work, will help? Do I simply need to man-the-f**k-up? Pistonheads members can be assured that I am powerfully built! [
Any shared experience appreciated.
