Just found out about a little device which clips into the key hole on the drivers door......
"...The custom door plug is removable and reusable as often as you like. It can be popped right off if you need to use the key anytime, and it also has a 14-stage proprietary finish process that matches the Porsche door handle perfectly...."
Go to www.bumperplugs.com to see them - I should get commission for this!! [
What a neat Idea [
Beno
What a neat Idea [
Beno
