Morning Folks,
I'm trying to get the door pillar trim off the passenger side to provide access to run a DAB antenna cable down to behind the dash. I've taken off the 3 x screw caps but there were only screws (that I could see) in the lower two holes. The upper hole doesn't look like there is anything in there.
However I can't get the trim off - the lower part is free to move, although restricted by the top of the dash, but the top is stuck fast - putting a trim tool in to try and pry it sounds like I'm starting to rip the panel. I've removed the left hand side of the front trim (at the sun visor) but this hasn't helped.
Looking for some advice here as I don't want to force it off and destroy the trim !
Thanks,
Andy
	Thanks,
Andy
