Door microswitch
chriscoates81
Hi, where abouts is the door microswitch located. I think it might of moved slightly as my passenger door has to be shut with quite abit of force for the window to rise and i would like to adjust it.
There are 7 microswitches in each door. Take a look at the Technical Articles section for a description of each.
It sounds like it might be the door open/closed switch in the door lock itself.
Ok is that a door insulation off job then? Ill have a look at the articles tomorrow when ive got time cheers fir the quick response.
Unless the cables are obviously frayed, I wouldn't worry. The passenger side window gets used a lot less, so doesn't suffer the same wear as the driver's side.
Yea thats true. As my girlfriend isnt in my car much it hardly gets used. I did notice on the drivers side that the wire that had snapped was bare. I thought it would have had some insulation on, possibly like what is on the wires in a push bike.
