jonnyporsche
If you have a failed abs sensor, meaning if the warning light goes out after starting the engine but comes back on when moving it is NOT AN MOT FAIL .........untill next month when the rules are changing.
How would they know the ABS light comes on when moving- rolling road brake tester?
ORIGINAL: rsmithholmfirth
are they doing road tests now?
ORIGINAL: 944 man
Id heard that it was supposed to be all brake testers now, and no inertia meter road tests.
ORIGINAL: Lowtimer
They can and always have done for vehicles with mechanical LSDs which can't have brake testing done on roller type testers. Such as all late 944 Turbos for example.
ORIGINAL: Lowtimer
ORIGINAL: 944 man
Yes, a lot of people have heard fantasy versions of the new test procedures. There is a lot of nonsense and disinformation being put about. The facts are all here:
http://www.motinfo.gov.uk/htdocs/index.htm
Part 3.7
Method of Inspection
The brake performance test must be carried out on a properly calibrated and maintained slow-speed roller- brake tester designated as acceptable for the statutory tests, except:
· vehicles for which a roller brake tester is not appropriate, or
· at premises without a roller brake tester where approval has been granted for the test to be carried out by other means.
Certain vehicles may not be suitable for testing using a roller brake tester. Testers should take account of the vehicle's drive configuration, transmission type and any Vehicle Specific Information before deciding whether a full or partial roller brake test is appropriate. If additional information is available from the vehicle manufacturer, then this should also be taken into account. Unsuitable vehicles should be tested using a properly calibrated and maintained decelerometer or a plate brake tester designated as acceptable for the statutory tests, see Sub-Section 3.7B and C
ORIGINAL: TTM
ORIGINAL: Lowtimer
Sorry for being thick but do you mean the LSD will add braking force in addition to the service brake in case rollers do not rotate at the same speed?
Or perhaps the LSD will be damaged in case of imbalance between rear brakes?
