Mr.FixitNorm
I spent some time today checking the AFM using the clarkes garage checking guide as I still have a slight problem with the car occasionally stalling when hot and having a low surging tickover when cold. All seems well with the AFM with all readings being in spec. After reading throught the trouble shooting guide on clarks I decided to test the DME temp sensor.
I've never `seen' the DME unit itself, but there's a ply board in the passenger footwell, with a metal frame behind this which seems to have a box attached to the back of it ( the DME ?? ) Anyway, not being sure how to get to the dme to check the temp sensor, I decided to check the sensor itself, I got the plug off, but I couldn't get any sort of reading from the sensor itself. when I put a meter on it, it was not closed circuit, neither pin gave a reading to earth and I couldn't get any sort of ohms reading through it either???? It's almost like it's open circuit.
Does anyone know what the engine ( 2.5 16v ) should idle at when cold? as mine only sits at about 900rpm which seems a bit low, and would possibly account for the stalling and erratic idle if the DME isn't getting a proper engine temp. reading.
Any thoughts??
Cheers,
Norm
Any thoughts??
Cheers,
Norm
