The specs are here: http://www.porscheclubgbforum.com/tm.asp?m=230692 The sensors wear through when there is about 4-5mm left on the pad.
Discs and Pads
- Thread starter Richard_Hamilton
Question on front disc and pad thicknesses, minima etc.
What is the thickness in mm of new front disks and what is the recommended minimum thickness before they need replacing?
Secondly, when the brake pad wear indicator lights up, how much wear (again in mm) is left of the pad?
Suspect my front ones are getting near the limit, but just want to check what the corporate forum wisdom is on this.
Many thanks
Many thanks
