Different manufacturers seats?
jmelhuish
Hi,
Has anyone installed seats from a different manufacturer in your 944? If so what were the pitfalls and any positives found? Also any recommendation to aid installation.
Do you mean series manufacture seats, or Sparco or Recaro race type seats?
If youre fitting other manufactuers (or later Porsche) seats, the easiest/best way is to remove the 944 runners from an old seat and to then adapt the new seat to those.
If youre fitting side mounted race seats then, for most applications, Id suggest fitting the brackets to the existing floor mountings; and then machining bobin type spacers to make up the space between the brackets and the seat ([;)]). For a more secure fitting Id still do this, but Id extend the replacement bolts through the floor and a reinforcing plate.
Simon
