Coolant
Hilux
Overheated at Silverstone last night [:(]
What coolant should I use to replace the tap water currently in it?
Is it a Porsche specialised coolant or a `Halfords` one?
I believe that by using an antifreeze it increases the boiling point of the coolant and therefore it becomes more efficient.
Probably an old wives tale and if so I'm sure there are more knowledgeable people on here who have views on this subject.[:)]
That's absolutely right, plus it is a corrosion and hence sludge inhibitor.[FONT=verdana,geneva"] [FONT=verdana,geneva"]Even with cooling system filled purely with tap water I'd not expect it to overheat and certainly not with antifreeze as recommended (and I guess several other 944T's didn't to bear that out) - maybe it's in need of a flush?[FONT=verdana,geneva"]
There was a thread on this recently - see http://www.porscheclubgbforum.com/tm.asp?m=232491&mpage=1&key=antifreeze&#232491
Hope this helps,
Phil
I think the manual calls for 'Phosphate free' antifreeze. I need to do a coolant change at some point as well... anyone have any advice on which brands are suitable in the UK? I couldn't find any labelled as such in Halfrauds.
Long life "red" coolant - a bit vague I know -is what I was recommended to use.
Make sure what you put in is the same colour as that which is already there. I gather you can get a reaction in the system if you mix blue and red.
Hello - agree with checking with the Porsche shops re what they use.
The phosphate free product highlighted above says not to mix with non-organic products - It is likely that your existing coolant is non-organic.
The key point for your 944 is that the coolant is appropriate for aluminum cooling systems. Most are these days - but ensure the label states it.
In Canada - the newer "long life" coolants are red but traditional color has been green - not seen a blue one yet.
Oh - and here our pre-mix coolants are good for at least -34C with the desirable target -40C (it will get that cold in western Canada at least once a winter....)
