Connectors
JohnCRS
Somewhat embarassingly I have to admit to being unable to separate this connector on my 981. (I have done it before but forgotten!). I have tried a screwdriver in the slot and pressing the tab and various other approaches, but it remains absolutely solid. It connects the main loom to the driving lights and side repeaters and there are two, one in each wheel arch. Any experience greatly appreciated.
John,
Photos of equivalent connecter on 987, which looks similar, but not identical to yours, so not sure if this is this is helpful. Second photo shows the two parts separated. You can see the catch on the male part that locks into the square hole on the female part. As I recall, I had to push the parts together quite firmly, while pressing the release lever, before I was able to pull apart.
Ian, thank you for this. That is the best guide that I have seen. The thing I don't get with mine is that I cannot see any sign of a tab in the square hole when it is connected. But I will go back to the garage and have another go.
I suspect the release tab is located at the back, so you may need to prise the fitting away from the bulkhead in order to separate it. ??
Regards,
Clive
Thank you both. Got it apart, firstly by unclipping the connector from the underside of the headlamp housing and then by sliding a thin screwdriver in to release the tiny clip from the opposite end to the tab (if you see what I mean) It then released easily. It is one of my issues with modern electrics, that they use so many different types of connector, each with their own release technique.
Anyway, thank you both for your help.
