chrisg
Geoff I've little or no knowledge about the clutch system for the lux - I believe in layout and function it's identical to the Turbo version but less beafy. If I was you, I wouldn't fit the turbo clutch - yes it's sprung but with two lots of springs to take up the extra torque. In addition to this, the coverplate has much higher pressure, so to cope with this the release bearing and fork are uprated and the clutch bellhousing is a different part. My understanding is that the torque tube is basically the same, the gearbox is not a Porsche box but an uprated version of the Audi one that was fitted to the Coupe - hence the bellhousing shape at the back where the box meets the TT (clutch position in the Audi). The Turbo box is uprated and modified strengthed etc with an LSD and oil cooler fitted, still basically an Audi box, even the drain plug has the Audi rings on it ! yours Chris
