Choke problem?
- Thread starter james944
Copperman05
Edd
I'm not familiar with the design of the Motronic system but faults in such systems are often temperature sensors not returning the correct value to the injector control system (either because the sensor is duff or the wiring has broken), or blocked injectors or pipework. Early Bosch stuff tended to be very simple so there wasn't much to go wrong.
If you are practical then you can do worse than work through the system methodically, probably with a garage manual or the relevant pages from Clark's alongside you. If not then it may be a case of taking it into a garage and coughing up.
