Changing Engine Mounts
- Thread starter 944 man
Catamax944
edh
After that experience I would definitely concur with Alasdair's method on here, and remove lots more bits. Speak to Simon @ ph though, he seemed to think it was about an hour a side - Even 3 hours at ph sportscars labour rates isn't going to break the bank is it?
simdel1
It would have been quicker if I hadn't done the first part of the job and it didn't help that neither of us had done this job on a 944 before. Next time I think it would easilly be a 2 hour job.
944 man
ORIGINAL: Catamax944
Took me about 3 hours to do it by dropping the crossmember . It's not hard ,if you have the time do it yourself and save some money.
Not bad going, but I suspect that a well-used Turbo will be far more difficult. They have a reputation for being, due to the heat (exhaust on the OS and turbo on the NS) and the reduced access.
Simon
Ewan
From you chaps are saying, if they bill me more than 3 hours I should ask why. Let's wait and see!
944 man
ORIGINAL: Jon Mitchell
Depends really..
Its one of those jobs which can take an hour and a half as Jim said, or it can take forever.
We did a late turbo the other day and it was a real headache, although we expected it to, the engine mounts were completely shot to bits, which often means that the long threaded stud that comes out of the engine mount just turns with the nut, and turns, and turns.. and guess what, on this particular car they did just that.
If you catch them early, which is on an 8v engine the lower distributor cap screw head being bellow the headlight bar, rather than level with or just above it, then it is not a bad job and can be done in 1.5 to 2 hours. If they have completely split, it can turn into a nightmare.
Make sure you get bolts with them, the new design has a shorter bolt than the factory original ones.
The one we did the other day took us a total of 4.5 hours and we had to cut the threaded section, we also changed the steering column UJ section at the same time, always a good idea if it has any play (rotational or side to side) on any of the joints.
Simon
