Chaps,
This is related to (but separate from) Chris's Central Locking question ...
I have factory-fitted central locking on my S2. It also has the factory-fitted alarm, which is linked to the central locking. (i.e. Unlocking the car deactivates the alarm.)
I have found that when unlocking the car, the alarm will often sound. The way to stop the alarm from sounding is to activate the central locking system again, effectively 're-unlocking' the doors. I usually unlock the doors using the remote central locking, which is wired from the aftermarket alarm (i.e. not the factory-fitted alarm) to the central locking system.
I know that the actuator in the driver's door has five wires, and one of these is to signal to the central locking system that the driver's door is unlocked.
That much I know. Everything that follows is guesswork ...
I am guessing that the alarm is connected to the wire from a door actuator that signals when it is unlocked. Unlocking the car sets the alarm off if the signal is not sent properly to the alarm that the car has been unlocked.
'Re-unlocking' the door silences the alarm, presumably because it correctly signals to the alarm that the door has been unlocked and hence turns it off.
Does anyone know how the fact that the car is unlocked is sent to the alarm? If it is from the actuator in one of the doors then it is possible that the actuator is not sending the signal correctly, which could mean an iffy connection in the actuator.
If it is NOT from one or other of the actuators, does anyone know how it is sent?
All help, suggestions or guidance welcome - thanks.
