Cayman wheels
- Thread starter 944Turbo
blade7 said:Look good to me. Will they clear the wheel arch though?
I think they will just clear but it is close. The Bridgestone tyres currently fitted (265) are actually quite wide in the sidewall the way the rim protection is designed in. I have heard it said before the N-rated bridgestones are wider than the non n-rated ones of the 'same' size. Worse case the arches need some work anyway so I could always mod them slightly. The fronts are 235. I haven't worked out the offsets yet relative to the originals, they were a fair price and local so I decided to just try them!
Tony
Andy
I had 5mm shims on the front so the 996 wheels I had on there cleared the hub centre, I haven't tried these without the shims. The rears I think are going to be sitting 12mm further out so 265 on 9" rims might be too much for the arches I could drop to a 255 tyre though,
Tony
blade7
Well-known member
944Turbo said:Thanks,
Tony
I've got 265 N rated Michelins on 10" wide rears on my turbo and they clear easily. I think you've got too much offset, unless you're going for the stretched tyre look Bruv [
924Srr27l
http://924srr27l.co.uk/wp-content/uploads/2016/08/wheels-825-Medium.jpg
http://924srr27l.co.uk/wp-content/uploads/2016/08/wheels-567-Medium.jpg
R
Diver944 said:... I do like the look of the chunky 5 spokes []
I agree, they are probably my favourite of modern Porsche wheels. I'm note sure on a 944 though, if I'm honest. Perhaps a better picture will sway me ;-)
Tony
