Has anybody got the procedure for removing this unit to get it checked/repaired?
If i put the fuse in my aux heater just keeps running without lighting/heating even after the car is powered off and locked. So I have to remove the fuse or it would run the battery down. I suspect its the controller. Unless you know better? (The fuse was missing when I bought the car so obviously the fault existed before I bought it.)
Or is there something else I can try. Durametric cannot see/communicate with the unit.
(Its the diesel powered heater mounted inside the passenger side wing.)
Thank you
Cayenne V6 3.0TDI
Thank you
Cayenne V6 3.0TDI
