Cayenne Air Suspension Failure
Hi all, the air suspension is having issues on my 958.2 Cayenne.
I checked the fuses and the 40A fuse for the air suspension has blown.
Been advised that I need a new compressor, which is c.£2k from Porsche.
Anyone else has this happen ? Just curious if anyone recommends another part (eg presume various other VAG models use the same part).
Also, I read on renlist that the compressor can be put under strain if there are leaks in the system. If anyone has any tip for how to try and test for leaks, would be grateful
Thanks in advance for any guidance!
Compressors start at just over £100 new on ebay, they work fine, spend about £180 and you willbe sorted, easy enough to change too
I’m new here as I’m considering a 957 as an off-roading project, but I’ve had a Range Rover with air sus and rebuilt the hitachi unit they use.
The Porsche units seem to be wabco and you can get rebuild kits for them too. The seals fail which means the compressor has to work twice as hard, which often means overheating and failure.
Get yourself a rebuild kit and have a go, it’s easy even for a novice and kits are cheap enough for a punt.
If you have a leak you’ll see the car sink overnight either on one corner or the whole car. The compressor will not run with the ignition off.
