Cayenne 955 V6 3.2 Cooling/Radiator Fan on all the time
karlj0
Hi
My Cayenne V6 3.2 cooling fan kicks in as soon as i start the car and stays on until half a minute or so after i switch off the engine. Even from cold. It sounds like a 747 taking off and must be a drain on the electric system.
Can anyone please help?
Hi, the fault is definitely the water temperature sensor. I have just had mine replaced becuse of the same symptoms.
Does anybody know if there is a relay or fuse I can remove temporarily to disable the fan until I get chance to get it into and Indy?
Should be a fuse in the fuse box under the bonnet on the right as you look in, just pull the fuses til it stops!
