ianthow said:I agree that stainless steel nuts may seize on stainless bolts, but at least they will not corrode away. Use some copper based anti-seize paste on the threads during assembly to minimise the risk. The nuts I used were flanged with a serrated face to prevent loosening (see picture). If you need to split the joint at a later stage and the nuts have seized solid onto the bolts, the hex heads should still be intact so, with decent ring spanners/sockets, you will be able to twist and shear the bolts.
I've used similar flanged hexagon nuts before, but like you said, they still seize. I imagine that a completely different metal would be better for avoiding galling, there must be something that is gall resistant, strong and corrosion resistant? Do you think something like these phosphor bronze nuts might work : [link=https://www.accu.co.uk/en/hexagon-nuts/268731-HPN-M10-PB]https://www.accu.co.uk/en/hexagon-nuts/268731-HPN-M10-PB[/link]
