castrol in Asda
- Thread starter colin944
MartinRS2K
Oil always used to be sold in 5 litre cans this seems to be a way to make you think its cheap, whereas more expensive as you will need to buy 2 x 4L cans and then may have up to 3.5 litres over as spare.
I'm not sure about which oil to use on a Turbo ,but I use semi synthetic in my S2 as I feel that full is just too thin for my engine.Also the Factory states that the engine can use 1lt per 1500 miles so changing my oil as I do every 5-6 thousand miles means that I could potentially use 4 lts in the interim period.
Copperman05
Edd
Copperman05
ORIGINAL: colin944
FWIW Synthetics are not thinner than mineral oils, a 10W40 mineral will have the same viscosity as a 10W40 full syth, you can also get synthetic oils in thick 20W50 and 10W60 grades just as you can mineral based oils.
I think the confusion comes where fully synthetic oils are more suitable to wider multi-grades, such as 5w50, 0W40 which are not possible with mineral oils, but it doesn't mean you have to use these grades to benefit from the advantages from using synthetic oil.
Edd
944 man
Ive been guilty of saying it myself, although it was correct in context because the synthetic in question were 0W & 5W.
Im not sure about S2s, but I believe that all 968s left the factory with 5W- synthetic oil. Its a shame that many of these later engines (2.7l, 3.0l & 3.0l 968) didnt endure well enough to still suit the grade now. Conversely, my 1985 series one 944 ran for ever on ProS 5W and, whilst it showed slightly lower oil pressure as a result (hot and cold), it never used a drop!
Simon
