I took my 997GTS out for a very short run today after being in the garage about a month and I was pulling into the drive it started leaking water.
The water was running down the inside of the front splitter, just underneath the nearside headlight. The car is not running hot and doesn't seem to have lost coolant, the coolant level is fine. It does seem to be water, rather than coolant, that is leaking.
The washers work, but the headlight washers do not.
I suspect a leak from the headlight washer, but it requires the removal, as far as I can see, of the front splitter and maybe front bumper to access. Is that likely? If not, any other ideas?
The car is under Porsche warranty, with breakdown. Should I call the breakdown service, call Porsche to book the car in, or call an independent, since I'm pretty sure warranty won't cover this? Northmore do most of the work outside the annual servicing, which is done at Porsche Reading.
thanks for your help, everyone.
