Can you use S2 coil springs on a 2.7 to reduce the height at the front by 10mm ish and stiffen the ride ? It sits slightly nose high and is a bit wallowy on the front too. Has sachs oil dampers on.
Or can you use a complete shock and spring assembly if one was available from the S2 ?
