aholymanjones55
After my recent France experience of speeding fines incurred when running-in the 718 B GTS, I thought I would post an update as I was somewhat taken aback when I discovered on researching whether sat nav are still illegal to use in France (as I thought) to find that both Tom Tom and Garmin have found a legal workaround to handle the many camera’s that are now in force.
Although I have not checked out for Garmin this, my research is on Tom Tom ( I would imagine Garmin have taken a similar approach).
In 2017, 26m speeding fines issued, generating some Euro1Bn in revenue from the 3,200 or so active camera’s. The Yellow Vest movement is thought to have started on the back on discontent form rural France on the impact of the French Government reducing speed limit on the B roads from 90 kph to 80 kph and the cost and massive volume to them of the speeding fines being imposed, that typically seem to fall to the drivers in rural France.
Given this information is so poorly disseminated makes sense to pass on what has been unearthed. I genuinely thought Sat Nav’s like Tom Tom’s were illegal to use in France post 3/1/2012…..introduced a little over seven years ago.
The official stance from Tom Tom states:
Since 3rdJanuary 2012, it has been illegal to receive warnings about the position of fixed or mobile speed camera when you are driving in France. To be complaint with this change in French Law, speed camera location are no longer reported but instead areas of danger are indicated as danger zones or risk zones. Tom Tom Danger Zones warns you about both danger zones and risk zones in the same way.
A danger zone is a zone specified by French law. A risk zone is a temporary danger zone reported by users.
You may use a Tom Tom, set up to tell you when you are about to enter the so called Danger Zone. Dependant on the type of road you have a range of distance to travel and then you are clear.
Specific camera site locations are not available and a danger zone icon is shown as you approach the zone.
The minimum length of the zone depends on the road type and is :-
The location of one or more speed cameras, if any, can be at any point within the zone.
If two danger zones are close to each other, the warnings can be merged into a single longer zone.
Critically, in my view danger zone warnings are displayed, when no route is planned. So you actually don’t need to use Tom Tom for navigation (continue to use the PCM) using Tom Tom to flag up Danger Zones with the warning bleep and visually via the warning alert icons.
You will also receive a warning sound/bleep…..
You will see the system flags up an Alert on top left of the Tom Tom screen and Route Symbol on the road you are travelling.
So I think this cracks this issue on being on top of, and legal for driving in France, when using a Tom Tom.
In summary, get a Tom Tom with French Map/Europe loaded and make sure Danger Zone Alerts is activated in Settings, (Typically a 3 months free service is provided when you first buy) and then you will need to have subscription service to keep up -to-date and make sure Warning Sounds are On……
Tom Tom keeps the data up-to-date by way of updates, hence the need to be connected into their system by a subscription.
The fines for illegal use are Euro 1,500 and possible confiscation of the car. So important to get this right.
- 300m for roads in a built-up area
- 2000m (2K) for secondary roads
- 4000m (4K) for motorways
