camshaft knocking
- Thread starter liskit210
PSH
Pete
The stuck tappet sound more feasible because after the 200 miles home it has sat outside for 2 weeks, being started only once or twice because the day after i got it, it wouldn't start, no spark etc. I checked DME relay and disconnected the main fuel line which pumped petrol into a jar with gusto. I then removed, tapped and put back the ignition relay and hey presto it started.
So, do I just start it up and let it idle for a while/until the knock goes away?
PSH
ORIGINAL: liskit210
Yes but personally I'd do a few checks first, crank the engine over by hand, all should be quite ie no knock. If you do hear anything set crank to TDC and check timing marks. There's a viewing hole in the top of the bell housing on the passengers side for the crank, cam pulley mark is at front just to the right of the distributor cap views through a small hole which should be plugged with a small grommet but not always. If these marks line up then I'd feel safe in turning the car over, I still believe your problem is a stuck tappet but it's always best to check first.
Pete
timmyturtle
Apparently the tappets were changed by the last owner,but as i know him as a lying b`stard i doubt it was done or at least not properly.
BTW has anyone had those stone shield/guard transparent sticky plastic things fitted? Mine had them on all wheel arches and one panel each side between the rear arch and the B post. Looking through the invoices I see they were fitted in 2007.
All of them had multiple rust spots behind them and looked shabby so I removed them yesterday and needles to say some of the paint came off too. [car was resprayed in 2006 at huge cost ] Around the rear arches they seem to have encouraged more rust than if they'd never been fitted!
Diver944
ORIGINAL: liskit210
They came as standard from the factory and do a good job of protecting those areas from stone chips. Alas they can't safeguard against a poor repair underneath [&o]
ORIGINAL: timmyturtle
Common trait that, being a liar and bodger!
