Cam cover gasket
Red_Baron
Hi all,
Busy refurbing cam cover and inspecting the cam chain & tensioner at the moment. I'm now ready to put everything back together and I'm just wondering if you need to apply any gasket sealant to any areas when fitting the new cam cover gasket?
If its a brand new gasket, then no, you shouldnt need to use any.
Are you replacing the spark plug hole gaskets aswell.???
If not you might find youl have oil in your spark plug chambers.....
Cheers Dave,
Yes, I am replacing all the spark plug hole gaskets and also the cam cover bolt rubber washers and the rubber 'O' ring found in the top of the cam cover. Two of the spark plug holes (no. 2 & 3) had quite a lot of oil in them, the old gaskets just crumbled away when I removed them.
Yes - there was a technical directive from Porsche that subsequently specified sealant be applied (sparingly) at the corners and where the gasket bends upwards over the curved hump at the end of the cylinder head. Just did this myself - used Permatex Ultra Grey.
Good luck
