Hi, new member & 1st time poster needing help! I upgraded to a 2004 Manual C4S at the start of this year and the car and love it but it did come with a issue of the starter motor squealing on starting. Decided to change the motor myself as I have a garage and am quite handy with the spanners! After removing the various bit to access the starter and removing the 2 bolts fixing it to the bellhousing I expected the motor would come out. However it is still solid and hasn't moved at all despite my efforts using a piece of wood & hammer, oil filter strap to try and twist it, slide hammer attached the cable bolt etc. It was suggested to put the bolts back in & re-connect the starter cables and try flicking the key to jolt the starter free which I tried however when I turned the ignition the starter did nothing. The fuel pump primes, ignition lights up ok but nothing. I tried locking / unlocking the car and re-attaching the throttle body and airbox sensors but nothing!
Anybody have any suggestions what the problem is or how to get the starter loose?!
Many Thanks,
Martin
Many Thanks,
Martin
