Hi, here is the problem, thoughts greatly received
Early this morning five miles down the road, brake boost failure, no warning lights nothing, pulled over (eventually) turned off ignition, pumped brake pedal several times to ensure that the pump if it wanted too would engage upon turning on the ignition, you guessed it, nothing.
Nursed the car slowly home, fluid level has risen in the reservoir by 6-8mm,
My initial thoughts were possible relay but, I don't think this would influence the fluid rising, not yet knowing the internal workings of the pump could a return valve failed and the fluid stored in the circuit returned to the reservoir that way.
Just a little history, the hydraulic fluid system was changed 2 years ago including the bleeding of the PDAS for the 4 wheel drive , the brake fluid was changed again 1 month ago after a full suspension refurb, 250 miles on and the problem has occurred.
Kevin
Kevin
