Busy tinkering today, seat belts in window sorted.
ukmastiff
This morning I fitted the static 3 point rear belts. should have been a 60 minute job , however I'm ashamed to say that I put bits in the wrong way round about 3 times and did struggle with one bolt under the seat.
Then I stripped down the passenger door in an attempt to fix the passenger electric window , was it the regulator / motor ?
nope
Someone had deliberately unplugged the window switch which is worrying as they must have done it for a reason ?
The window is 'currently ' working but I'm a bit worried there.
Well done on the belts.
Window; my (optimistic!) guess would be that they dismantled the door for some other reason and forgot to re-plug the window. As it's the passenger side, they may not have had cause to use it and hence not noticed ... hopefully ... fingers crossed and all that! [&:]
