Brakes
- Thread starter Guest
Speak to Steve on 01322 441591 and tell him Chris Gladwell with the blue 912 sent you. He will probably curse me for sending him another German rust box as he is a Ford man at heart, but don't hold that against him!!!![
Can't remember the cost but I know it will be fair.
912UK
I have a tool some where I think Alex at Retro has it for blowing out the pistons.
Mark
Evil J Guano
They are up in Cheshire near Joddrell Bank radio telescope.
Usually returned within two weeks, know their stuff.
I would get them all done too, as you will need to drain the system you may as well.
G
Heres the upshot:
for rebuild - 65 to 66 early rear calipers (the ones with the cross over pipe)
£66 plus vat each
fonts £60 plus vat each
which makes:
£296 for the set
£155 for the rears
what does that sound like?
It would be great if it was a supermarket "" fix three get on free?!
Evil J Guano
Take some pics as you take them off as they put my crossover pipe on upside down and took me ages to figure out what was wrong!
Also I would get the closed brake pipe spanner, not essential but helps you not to strip the soft alloy nut.
You'll need a friend to pump whillst you tighten too [
Jon Darlington
Evil J Guano
(the crossover took 2 mins to swap, meant the bleed screw was the wrong way up, the main thing I think is they are pressure tested, which is nice!)
Hmmm legless huh... me thinks I have a reputation...
Jon Darlington
ORIGINAL: Evil J Guano
Make sure you know what fluid was used previously, as you don't want to mix, infact I would flush it while you are at it.
Good point I don't think I have ever flush mine out[8|]
Jon Darlington
How often do you think it should be done?
Evil J Guano
I left a half full jam jar filled with mineral fluid open to the air in my garage, and in 3 months it had absorbed enough moisture to fill the jam jar, I kid thee not.
Jon Darlington
