Brakes: How Hot?
- Thread starter 944 man
944 man
For my £10-£30 I will be able to see how my tyres are working, tell whether my brake cooling is effective, even see hot spots on my cylinder head!
The question has to be: why wouldnt you? [
Neil Haughey
I paid £20 for it a few years ago but IIRC it was on sale from £40 from Maplins & it has a temp range of -60 to +350deg; ideal for tyres, checking the rad (diagnosing stuck thermostat etc), very handy device.
From experience, pointing it at the exhaust manifold at idle will tell you which cylinder is misfiring (as soon as you rev it it goes beyond 350deg though), and pointing it at the front wheel centres helped me find an overheating wheel bearing recently but the disks are way beyond the temp range & tbh I'm struggling to think of a diagnostic reason why you'd need to measure them [
Also, now that I have one to check against I find I can judge tyre temps (inner middle outer) by hand accurately enough for my purposes so on my own car I don't actually use it all that much now.
Most useful for small variations in temp where the hand or eye isn't subtle enough to spot problems, for brake issues I'd look for burnt pads, discolouration & pedal feel etc.
Hope this is of some use.
Tony
Eric_Oz_S2
edh
I can see their value in 40 min races, or trackday sessions with a 1500kg car - medium blacks will work with cooling & decent pads, but it doesn't really cost much more to go bigger. 5 years ago I bought some big blacks from OPC Exeter for £400 - never fitted them (sold to John Sims) as I decided that medium blacks actually worked fine & I didn't want to buy 17" rims.
944 man
If I need new discs, pads and work on my calipers then this would be a good time to upgrade as itll be extremely cheap. 928S4 discs dont cost any more to buy and hopefully the extra caliper and adapter cost will be mitigated by my being able to to have all of the work completed in one go, without the car being left off the road.
With a little man-maths this is all possible... [
George Elliott
Light Straw, Dark Straw, Blue, Mauve etc are in the 280, 350 plus deg range.....as seen on steel manifolds, exhausts etc.
George
944t
Super_Marv
