scam75
Well-known member
Afternoon all
As it says in the title, I am getting brake shudder through the pedal above 60mph, nothing at all under 60mph. It is more pronounced when dabbing the brakes, firm application shows a bit of shudder but not much. There is no shudder or wobble at all off braking at any speed and wheels are all balanced ok.
Discs have been changed all round in my ownership, never cured the problem. Front calipers are recently refurbed and rears were new about 5 years ago.
We did notice a rear wheel slightly out of true on the rolling road last week, passenger side. It is balanced fine though.
Alastair has also cleaned up the hubs and mating surfaces which helped maybe 10-20%. We had gauges on the discs a while back and there seemed a little bit of run out on the drivers side.
What could be causing the issue? The wheel, a wheel bearing, a disc or a caliper issue maybe?
Suggestions welcome!
Stuart
Stuart
