Brake Pads
talking about dust removal rather than the pads themselves - have you tried Wurth wheel cleaner? It's in a different league to the normal stuff.
Hard to accuse you of not trying if you are melting brake pads [:D] First line in protecting the wheels is to put a wheel protection polish on them BEFORE the track day. Sniggering aside, I use Rim Wax (calm down now) which leaves the wheel feeling like it has a Teflon coat on it. Ref brake pads, I always used Textar ones on my 964 and when you and I were at Bedford and I was in my 964 I got the impression we were similar in speed and braking. The Textars have always performed well and lasted well for me. Textar are regarded as 'standard' but perform well and Steve Brookes who does a lot of 964 track days has tried a lot of brake pads and seems to be suggesting he'll move back to Textars now. I am 100% convinced there will be a few opinions on the best pads to use - much like the which oil to use question! Not sure what pads my 944 has in it, never bothered to look but they stop well (they are big reds so ought to!) and still have meat on them. Best of luck, Mick
I fitted some Mintex M1144s based upon a few recommendations on here and am really happy with them so far!
Hi Chaps
I'm after a bit of advice if you don't mind. I know mine's a 968 but after the Bedford trackday I figure we're all friends together.
Post Bedford I've had to replace all the brake pads and all the pad wear sensors. The front pads were almost new and all of them had plenty of meat left on them but the heat generated had caused the friction material to separate from the backing plate on every single pad. The wear sensors also packed up because of the heat.
I was running standard pads because my last foray into high performance pads (PF97s) resulted in a huge amount of brake dust that bonded
irretrievably to the wheels meaning I had to have the wheels refurbed...
For time being the car has a new set of standard pads on and new wear sensors but I can't risk this happening again so I won't be doing another trackday this year I don't think. However, once I've saved up some money I'd like to try some alternative non-standard pads so I can get back on track.
Any suggestions for pads that don't produce aggressive (grr...) dust?
James
All the best track pads pads produce nasty dust I think. Pf08 is available and supposed to be a bit better. Less aggressive pads like 1144 aren't as bad, but they don't stop as well... Maybe your other option is a second set of wheels?
I ain't no trackday headbanger (so may be talking even more rot than usual) but it sounds like you are generating some serious heat in there. What brake cooling system do you have? From recollection, there are some fairly smart things available which allow you to duct air from the front of the car and attach the other end of the duct pipe such that it points into the middle of the back of the disk, which then cools the disk by blowing the air out radially through the cast-in vents. Maybe something like this, with standard pads, could be the way forward? Oli.
Good point...and the the brake ducts on a 968 are very straightforward - plastic deflectors that bolt to the lower arm and strut, costing less than £100 iirc. I don't know if these were fitted to all 968's or just the cs?
Hi chaps Thanks very much for all the advice. Double entendres notwithstanding, the Rimwax sounds good Mick and I'll definitely give that a try. My 968 is a Sport and like all Sports it was built at the factory as a CS so it has the brake cooling deflectors mounted to the lower arms. I know that there is a mod for 964s that involves removing the front driving lights and fitting a duct to the back of the resulting hole. Presumably this is an option for 968s too... I'm never going to do more than a couple of trackdays per year so a spare set of wheels (and possibly tyres) is hard to justify as well as taking up space I don't really have. I guess I will have to take the plunge, buy one of the pad types mentioned here and apply the wax liberally at the same time. That's if I ever get the car back... The other things that happened at Bedford is the driver's door window mechanism lunched itself and a wheel bearing failed. The car went into Hillcrest to have all this put right (the parts bill alone is eye-watering) but it has taken ever since Bedford to get all the necessary parts for the window. Then, last Friday just as the car was finally ready to be collected, it boiled over while Hillcrest were washing it with the engine running and they don't know why yet... Summer will be over by the time I get the damn thing back [:mad:]
Damn, I do hope that the car does come back! Hopefully with not too terrible a repair bill! PF pads do seem to be raved about, so many a good wheel wax is an avenue worth pursuing. Was it not EdH who found that Bilberry Wheel cleaner could shift the rather hard deposits left over by PF pads? Regarding the brake cooling ducts I believe there is a mod for the 968. One of the motorsport chaps should be able to assist there. Whether they would stop stock pads fading is another question, considering how easy they are to fade with certain driving. M1144s fading a little on the track is not too surprising IME. I did think that on the road they were a big improvement over stock pads. M1155s may be worth a go, although they do not quite posses the same cold bite as M1144s. That said, they were an improvment over whatever crap I had on the front of my 106 GTI when I went from the stock 246mm brakes to a 260mm upgrade (they came with M1155s (the brakes were off a Xsara)), and I wished to stick with the stock wheel (after 'massaging the brake callipers to fit...').
The Bilt Hamber wheel cleaner is what I used - not bad, but not completely effective. Needs clay bar as well.. The 968 ducts are pretty good I think - so that's not the problem. Of course the 968 only had the same size brakes as an S2 so bigger calipers / pads would help with heat. Big Blacks with textar pads would probably work fine and be much less dusty. Not a cheap upgrade, but might do the job for you.
