If you were to force the brake caliper pistons into the calipers without removing any brake fluid could you force brake fluid out of the reservoir where the level switch fits ?
The reason for this question is that my 1990 C2 has just undergone front wishbone fitting and suspension realignment. I drove the car home from the independant specialists after the work had been completed and all appeared to be fine while I enjoyed the new surefooted handling.
Having put the car in the garage and been away working for a week I return and on opening the garage am confronted by a pool of what turned out to be brake fluid.
Having stripped out the carpet,spare wheel ,compressor etc from the front compartment I find yet more fluid laying in the wheel well and an empty fluid reservoir.
Curiously the top of the reservoir was full of fluid and the level switch also covered in the same fluid.
I'm trying to establish what has happened here , the people who carried out the work (well respected and long established ) are blaming a leak elsewhere ,but the braking system on my car is free from any leaks ,at least it was until I took it to be worked on.
I cleared up all the mess and refilled the reservoir and have had no leak yet although i won't go out in the car until it has stood a bit longer .
Any ideas anyone,
Steve
Any ideas anyone,
Steve
