Braided Front Flexi's for M030?
- Thread starter GPF
andy watson
Moderator
HEL sell hoses in axle pairs, bought fronts only for mine
ChasR
I can't see that HEL do lines for M030 fronts - I've emailed them direct to check though so hopefully they will get back to me.
Maybe getting some made up locally will be the answer - does anyone know if the fittings are just standard female on both ends as opposed to 1x male and 1 x female on the standard (non M030) ones?
Thanks again
chrisg
in answer to your question, for the M030 lines, its a female - female at each end. The hard line from the body has a male end with metric fitting that fits into it and is clipped in place.
At the strut end, the flexi has a female end from which there is an s shaped short hard pipe to the caliper. The female end of the flexi is held onto the strut via a fork/ clip type thing - identical to the ones used at the back for the rear flexis.
Hope this helps, if you need photos let me know ?
Yours
Chris
