987.1 Boxster (2007) 2.7 manual 100 k miles
Oil on outside of Spark Plug/ Thread when removed
Note this is not the tube that is on the coil pack
986/996 Engines have a Spark Plug Tube for each Plug which has a o Ring top and bottom You can remove this Tube from the cam cover and replace the 2 0 ring types for about 20.00 UKP total.Easy Job
Tube are more expensive but only need replacing if damaged
987 and 997 (.1) engines have done away with the tubes and have an 0 Ring (999 701 761 41) on top of the Cam Cover and one on the underneath
My question is
Can you get at the O rings under the cover without removing the coverCan you remove the cover without removing the engine
Another update from Porsche that make the job lore difficult
I have Oil in one of my plugs
THANKS[/LIST]
My question is
THANKS[/LIST]
