Thanks for the replys, I'll soak the lock in WD tomorrow and give it a try again. Having had a second play with it, it does feel like it could be for a different key.
I've finally seperated the boot glass from the alloy frame and what an epic that was! It was leaking like hell at the top and bottom but still bonded in at various points.
Going to clean it up tomorrow and paint it black again then try and bond it all back togeather.
I've bought new gas struts from Porscheshop that are apparently OEM but they do feel a lot stiffer than the ones on there, is the boot ment to open as soon as you press the button?
The current struts are so weak that the boot can lock again before you get around to it!
I managed to get 5 stuck screws out of the spoiler with WD40 after I had drilled the heads off to take it all apart, so nothing broken so far but it don't want to speak to soon otherwise I'll smash the whole boot lid!!!
I had heard that you could rekey the locks but can't understand how you disassemble the lock with the wrong key?
Tim
