Boost Gauge
944 man
The Stacks actually start at £53, making the choice even more difficult... However, the £15-er will win, I think, if it will do the job!
Id be interested to hear peoples opinion/experience, because even though I have owned many turbocharged cars, I havent ever fitted a boost gauge.
I dont want to now either, but I need to see how much boost Im really seeing and the binnacle gauge is notoriously unreliable.
I dont really see this as a permanent cabin fixture, so its only really the function that Im looking for. My first thought was Stack for £63 from Demon Thieves, who also offer a Mocal at £33. Bringing up the rear is a £15 eBay special from a vendor who is just down the road from me.
Over to you.
If you're ever likely to make it permanent, I'd go for VDO vision as they match the standard dials If you're interested, I've got a cheap boost gauge kicking about somewhere - I also have some spare exhaust / wastegate gaskets from when I had my Tial fitted at ph - they didn't use all the new gaskets
If doing it again I would go for a gauge that has a peak memory as looking at it, unless its in direct eyline is tricky at full boost.
ORIGINAL: JamesO If doing it again I would go for a gauge that has a peak memory as looking at it, unless its in direct eyline is tricky at full boost.
IMHO the only boost gauge worth having is a stepper type with memory/record and audible warning when preset boost level is reached, besides being very accurate they also look cool. Pete
It is a fact that adding gauges leads to added paranoia [;)] Personally if its a simple but accurate gauge then go for Stack - their backlit LED sytem is the nuts - got two in the Golf and a few enthusiasts that have seen them have gone out and swapped theirs for them.
ORIGINAL: Hilux It is a fact that adding gauges leads to added paranoia [;)]......
Ah the old, "How do I cure low oil pressure at idle?". "Put tank tape over the gauge." solution. :) I agree with the above. A boost gauge is a must if you are playing with a turbo at all and a tell tail of some kind would be really good to have. Stacks clocks are to die for. No competition IMHO.
Depends on budget, AEM do a nice one, available with all sorts of bells and whistles through e bay, a good quality budget one is the Racelogic one from Demon Tweeks and the like, i have one a good bit of kit, i also have a VDO unit in the 220 which as stated matches the dials and looks factory. I keep meaning to take them to work and check how accurate they are on calibrated instruments. Jim.
My Stack gauges were'nt any more expensive than others - shop around - you`d be surprised (and their backlighting is second to none)
