Battery
- Thread starter Aidietom
There’s plenty of choice for the replacement depending upon your budget, though you can’t really go wrong with a Bosch or Varta battery. You may need to reset the windows single-shot operation, and probably there’ll be a few warning lights when the ignition is turned on, but these should disappear quickly once you’re under way.
Unlike the 981 and 718 the 987 doesn’t have a battery monitoring system which needs to be reset when a new battery is installed.
Jeff
Also - windows need to be taught top and bottom limits for one touch operation. Open the window fully, let go of the switch, then "open" it again and hold for 5 seconds. Close fully and repeat the close, let go, close again, 5 secs. Obviously need to do both sides.
There's a throttle adaptation reset as well - turn on the ignition and leave it for at least 30 secs without starting the engine. You may notice a rough idle when you 1st start as it's relearning but again - sorts itself out.
As said, the battery is very heavy!
